I want to verify that I wont fry the motor driver before I try this.
I’m using a Redboard Plus. I want to power the Redboard with a 12V power supply through the barrel jack. Then I want to use the Vin pin on the Redboard and connect it to the Vin pin on the ROB-15451 Qwiic Motor Driver.
On the ROB-15451 Qwiic Motor Driver hook up guide (here: https://learn.sparkfun.com/tutorials/ho … 1630246818) it says “Operates from 3 to 11 volts with 12v absolute max”
But on the actual ROB-15451 Qwiic Motor Driver board, it says “11V MAX”.
What gives? Whats the actual max Voltage?
