I was looking at getting this board to produce sound effects as part of a user-interactive museum display.
My intent would be to use the Trigger inputs only (but I can do I2C control if necessary).
From other posts on this forum, I gather that there is a time delay between the Trigger and the actual sound output.
How much delay are we talking about? I don’t need an exact number, but (say) in increments of 100 mS?
Is it variable, and if so, what factors control it? [I gather from a similar Arduino device that the MP3 must be loaded and decoded after the trigger, and this takes measurable time.]
The sound effects I would use are only a few seconds long, if that helps…
BTW, I saw a similar forum post, and there was a brief reply recommending a WAV device instead of MP3. Would that advice apply to my case also?
Pete M.
Hewlett-Packard (retired)
Volunteer at Western Museum of Mining & Industry in Colo. Springs
P.S. - Nate, in case you’re reading this: You won’t remember I’m sure, but we met once 10-12 years ago, and you showed me around your facility. ![]()
