I’m having problems trying to use a .91in OLED V1.0 128-x32 display on a Qwiic mux. I suspect the reason is because of the pullup resister on the Mux and display. The documentation has not been updated for the display, but I’m assuming the jumper labeled I2C is the pull up resister and if I cut it it should work properly with the mux.
Could someone please confirm if this is the case?
Carl
