The Qwiic mux breakout is working on all ports except the last one, port 7. When I plug a known working device and cable in there the entire mux stops working (can’t see anything through any port). I’m guessing that this is not a bug but rather there’s a defect on the mux board that I got.
It’s very possible there’s something wrong with the board if all the other ports work except for the last one.
Have you tried swapping the device on port 7 with a device from another channel to rule out a problem device causing the trouble?
Yes, tried that with several of the other devices that i have here.
Sounds like a defect in the board.
If you purchased it via our website, just fill in the form [on this page with your order number and the URL to this post and we can get you a replacement. :-)](Return Policy - SparkFun Electronics)
