I bought a Qwiic Pro Micro last week. The first few times uploading a sketch (VL53L1X and OLED connected via Qwiic cable) the upload had no issues. Now however, if anything is plugged into the Qwiic connector, the upload stalls and just says “Uploading” indefinitely. I can unplug the qwiic connector, upload sketch, the plug it back in and everything works. While this is workaround for breadboard tests, eventually I will have this setup in a housing where I cannot use this “band-aid” workflow, as the USB will be accessible thru a hole cutout, but not the Qwiic connector.
This issue is present no matter the sketch content (even the basic Blink example). I have tried different computers, cables, sensors, verified IDE/port settings and it all seems to point to an issue with the board itself.
Any suggestions?
Thank you,
Chris
