Hello! I have a project where I have designed an enclosure for a sparkfun artemis data logger. The enclosure makes it easy to access the usb c port, but more difficult to take the SD card out. Is there any way to plug the usb c into a computer and view the sd card data that way? Thanks!
I did the same thing. The only way to get the data is described in the hookup guide under “SD Card File Transfer. “
You’re not able to access the SD card on the OLA as a mass storage device.
