Reading Batch PCB DRC error logs
Hi all,
for the first time the DRC has given me back an error, Eagle DRC runs fine and for the life of
me I cannot see an error in my design. I was hoping somebody could help me read the error file
to get some info on what and where this error is.
Thanks all,
Kevin
unmatched 274X paramblock OFA0B0 - len 6
Macro Name = OC8
Macro Consuming 5,1,8,0,0,1.08239X$1,22.5 [0]
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Beginning GCODE run
Ending GCODE run
Created 1958 polygons
Found 0 errors
Partitioning…
Grouping…
Distance testing
MergeCount: 1912
tests: 345010
Board boundaries: Rect: [0.018000,0.014500] → [3.356500,3.385000], w: 3.338500, h: 3.370500
Found 46 groups
lengthdb size 0
DRC space fail: [0x9bc2da0 0x9bcb070] 0.006780 - 0.006900
DRC space fail: [0x9bc2da0 0x9bcb0e0] 0.006780 - 0.006900
DRC space fail: [0x9bc2e10 0x9bcb070] 0.006780 - 0.006900
DRC space fail: [0x9bc2e10 0x9bcb0e0] 0.006780 - 0.006900
DRC space fail: [0x9bcb070 0x9bc2da0] 0.006780 - 0.006900
DRC space fail: [0x9bcb070 0x9bc2e10] 0.006780 - 0.006900
DRC space fail: [0x9bcb0e0 0x9bc2da0] 0.006780 - 0.006900
DRC space fail: [0x9bcb0e0 0x9bc2e10] 0.006780 - 0.006900
