Hi guys,
So I have a conundrum,
Basically I’m using a digital torque meter (MARK 10 model TT03) that has a USB connection. I want to know if I can use that USB connection on an arduino controller to shut down a motor once the value is 0 N/cm.
I assume that means the USB connection of the torque meter will give me an analogue output; is that a correct assumption? Also, can an arduino USB connection be used to control a motor or is the USB connection purely for the computer interface in order to program it?
I hope I’m being clear, otherwise I can draw what I mean; but it should be pretty straightforward
Looking forward to hear from you guys ![]()
-Val
