Received an incorrectly wired cable in XRP kit, need replacement
The title says it all. The black and red wires are swapped on the controller side of the connector between the motor and XRP controller. I am just trying to get a replacement cable, but customer support sent me here. How do I get this resolved?
Thanks.
That looks right to me
(note this photo is of the older beta version, uses same cables/motors/connectors)
Are they in the same order on the motor side?
They are not. I compared to the cable on the other motor, as well. It is definitely flipped incorrectly.
Also, if I swap cables, the problem switches sides. Basically, the robot goes in circles when running the installation verification routine.
Alrighty
You could either reverse the direction in code (reassign +/-) or we can get a cable sent out, whichever you prefer. Adjusting code will save time compared to waiting on the replacement
I get it, but then I would have to reassign on any future code. It becomes a note I need to recall for all development. Would it be possible to get a replacement cable sent?
Thank you.
Oh, would it help if I include the original order number? Order: 000443096, placed on September 1st.
Understood, we’ll get a replacement sent out ASAP - I’ll update this after it ships (should be tomorrow)
It’ll be headin’ your way shortly :slight_smile:
Thank you so much. My apologies for the slow reponse.
