I am looking for an inexpensive external antenna option for an iridium go sat phone, It apparently uses a TS-9 connector. I am looking for the sort of thing that can be put on top of a car roof out of the window. Would something like sku SKU: WRL-25068?
Yep! We also have another one but I’d recommend the one you mentioned if you’re going to put it on a car roof ![]()
Do I need an adaptor as well?
It looks kike you might need 2? WAAC1301 (from the FAQ) and a TNC to SMA
4G LTE Antenna Adapter SMA Female to TS9 Connector Coaxial Pigtail Cable 20cm 8 inch
