I’m brand new to Sparkfun’s Redboard, but not Arduino. I have followed all the instructions on how to set this up and expected it to just find the FTDI chip on it without any issues. I have downloaded and installed the FTDI drivers linked in the page https://learn.sparkfun.com/ftdiDriversMac
I’m running an M1 MacBook Pro with Ventura 13.2.1 and it won’t show up as a serial port when I plug it in. I’m assuming that these things don’t work with M1 Macs yet. Is this correct?
Many thanks in advance. Sorry if this isn’t in the right section. I don’t know what Artemis is
              Not sure which redboard you have, most don’t use a ftdi chip. It’s likely you need ch340 drivers instead, those can be found below.
https://learn.sparkfun.com/tutorials/ho … 40-drivers
              Thank you so much for your reply. I purchased this Redboard Qwiic Arduino Uno replica. I will try your driver link and get back to you.
https://www.sparkfun.com/products/15123
              Yep, that one definitely has a CH340.
Load the CH340 driver and you should be good to go!
Just in case the driver in sparkfun’s links don’t work, this might be helpful too:
https://arduino.stackexchange.com/quest … 4x-devices
              Thanks YellowDog,
I have done some searching on M1 Macs and the CH340 drivers to find a repo with an installer for the drivers. It’s still not working though.
I’ll keep on hammering away at it though and post when I know what the hell has gone wrong. I just find it weird to be the only one with this issue. Surely every M1 Mac owner has this issue.
Thanks again <3
              HAHAHAHA turns out we found the same link.
              OK… Anybody who has this problem please download the drivers from https://drive.google.com/file/d/1XY9kOZ … sp=sharing
The drivers from github didn’t work for me. They didn’t install any kext extensions. Best of luck out there, and keep nerding
