My power supply only outputs at 3 volt range. What is the problem here?
Photos of the top and bottom of your board please.
Everything looks fine. What voltage are you inputting to the kit?
It is 5v dc, 2a. To much amperage? to little voltage?
Try 9 volts in and see if you get 3.3 and 5 volts out.
9v worked. Problem solved. Thank you for taking time for my problem! AlanG.
Glad i could help!
