I am trying use a xbee attached to a PC to change IO port states and read ADC values from remote xbees.
I just got 2 XBee 2mW Series 2.5, one XBee Explorer USB and one XBee Explorer Regulated to play with.
I loaded ZIGBEE ROUTER/END DEVICE AT into one and ZIGBEE COORDINATOR AT into other one, had both with the same pan-id, defined their Node Identifiers.
And now? What else must I do? How do I check if they are associated? (there are no assoc leds on sparkfun boards)
Once they are associated, which AT commands can I use to change IO port state?
Thank you,
MeHale
