Hi folks, i submitted a design a couple of days ago and still theres no email from the drc bot… is this normal? Also when I uploaded the design I got a message that no drill points were found, is that ok? I’ve never used batchpcb so I’m a litttle confused, I’ve also emailed the zip to the support address to ask for advice, but no reply from there either… :?
If the bot finds an error with the drill data / apertures, I think it just stops short, spits out the error, and saves the processing power (not like it could fully check the board anyways).
So, this is normal I think.
So is my design ok? or is there an issue with the drill data?
