Hi, I’m not handy at all and need some help on what parts to order from here.
I am looking to pass an object with a RFID tag on the bottom over a RFID sensor/reader. When the object is over the sensor/reader I would like a 5 volt led light strip to go on ( light } and stay lit until the object is moved away from the sensor/reader. I would like it all to work on a house outlet for energy 110. If I can have that put together here and purchased that would even be better.
Thank you
You can design your system with a low-cost RFID reader like the MFRC-522, an Arduino UNO, a 5V RGB Programmable COB LED Strip and a 12V,2A DC adapter.
Thank you for responding. Is there a way ai could purchased it already made/put together?
[Thank you for responding. Is there a way ai could purchased it already made/put together?
Sadly, no. I’m not aware of anyone that makes specifically what you’re looking for.
If you can find a security company that specializes in rfid access, they might be able to build something for you but it won’t be cheap.
