ok, so sparkfun sells a horizontal connector for the EB-85A GPS unit.
i dont want to use the ribbon cable and connector, to much baggage.
i would rather use the same type of connector like this
http://www.sparkfun.com/commerce/produc … ts_id=8297
but in a female right angle version. so i can solder this connector right onto my board and then just plug the GPS unit right into that.
does anyone have an info on a plug of this type ?
From digikey…
455-1794-1-ND CONN HEADER SH 8POS TOP 1MM TIN $1.01860
http://search.digikey.com/scripts/DkSea … -1794-1-ND
(Same connector as the EM406, but 8 positions)
Thanks Ryan
this connector is a top entry make connector. Im looking for a right angle female connector that i can mount to the PC board that would plug right into the GPS module. i dont see any.
anyone know where to get a cable simular to this one
http://www.sparkfun.com/commerce/produc … cts_id=574
but in an 8-pin version to use on the ETek GPS 5Hz Receiver ?
