RN-41 Bluetooth module (noise problem) please help
I’m having some strange problem and I need some help with an RN-41 module please.
I’m building a light detection circuit (using LEDs and a light receptor), which sends a message to a PC, by bluetooth, when light is detected. Everything works fine when the bluetooth module is only powered (without starting communication), but when I start the communication with the PC a very strange noise appears in the light receptor output. I already have decoupling capacitors to avoid noise but still I have this problem. What could be the problem? I’d appreciate very much some help.
Thanks a lot.
Best Regards,
João
I’m attaching some images so you can identify the problem better. You can see the before and the after starting the communication… Thanks.
That trace does look pretty troubling. It would probably help to know what you’re using for a light receptor, and to see some schematic.
