I have been trying to use this module and I want to save power when I am not transmitting.
Here is the user manual - http://www.sparkfun.com/datasheets/Wire … oth-um.pdf
Now My requirements are these
keep the module connected to my pc
transmit “Hello” to pc when a button pin 12 goes high on the arduino, this will happen by button press
So when I am not transmitting, I want to be able to keep the device in sleep mode. The command for that is SW,8000
However my module is still consuming 25 miliamps when not transmitting. Has anyone tried this?
