Just going to design a new board but I cannot find the router bit size so that I can get the correct dimensions of the board
pmhunt:
Greetings pmhunt,
As a board designer you don’t need to know the router bit size, you just specify the dims of the finished board. They will probably use a smaller diameter bit to leave a small radius at an inside corner, perhaps that is really your question?
BatchPCB will allow any number of segments on an outside route (make a star shaped board if you wish), but no routes on the inside (you can’t place cutouts inside the board outline).
Comments Welcome!
I have used pcbpool and they routed to the centre of the board outline So you need to know the router bit size to get the correct dimensions
pmhunt:
Greetings pmhunt,
How does this relate to BatchPCB?
Comments Welcome!
