Dear All
We want an RTK for our Research Center (North Dakota State University) for several uses, such as marking points, making polygons (shapefiles), etc., and connecting the RTK to other devices, all applied in agriculture research.
we currently have the following:
-EM38 (electromagnetic Induction from Geonics), with a Juniper Archer 2 field computer. Can one of your RTKs connect to this field PC?
-Green Seeker ACS-430, with a GeoScout X logger, is any of your RTK compatible with this device?
Your RTK works with ArcGIS Filed Maps for Android and IOS? The idea is to mark points and use polygons, etc. Filed Maps in general
questions about your RTK products:
-SparkFUN RTK Facet L-bad, do I need to pay a subscription for centimeter accuracy? and if that is so, how much is that monthly?
-SparFUN RTK Facet, if I buy 2 of them, can I use one as a base and the other as a rover for centimeter accuracy GPS?
-SparkFun RTK Facet, is it possible to use a wired connection, and if so, what kind of port connection does it have?
I have many questions, but I want to buy something I can use for the current devices. Also, I am not an expert in precision agriculture. I am at the user level of technology. Thanks for everything, and I will be waiting for your answer.
kind regards
Sergio
