Hi All,
I am really interested in the SparkFun RTK Facet L-Band ($1500) for drone mapping work. I have been in GIS mapping for over 25 years and only require around 6 - 12 inch relative accuracy. I really like that Sparkfun includes the first year subscription for corrections through PointPerfect. I have an Auel EVO II Pro Enterprise with RTK. When the RTK unit is attached (No CORS base) I get around 2.5 - 7.5 feet of relative accuracy per WebODM quality reports. This works for some projects, but I would like a more consistent solution.
Some things that concern me before I purchase.
Not one of the reps on YouTube mention using this unit as a GNSS base station for an RTK equipped drone.
Can this unit be connected to a RTK drone using Wifi or Bluetooth?
Can an RTK base station use FIX when connecting to an RTK drone (rover)? I haven’t heard of RTK to RTK.
Can the export files be converted to RINEX easily for PPK workflows?
Can the current export files be uploaded to National Geodetic Survey OPUS?
When using PPK workflow, can user enter state plane coordinate system or is output always WGS84 with ellipsoid elevations?
What is the relative accuracy without the PointPerfect subscription?
Regards,
Gerry
