RTK velocity
RTK will not improve velocity accuracy, right?
I don’t know for certain, but I would imagine it would improve it slightly. It wouldn’t be a dramatic improvement though.
Velocity is measured by how far you’ve traveled between two locations in a given amount of time between the two locations. If you’re moving very slowly, RTK would probably help, but as speed increases things will start to average out and you wouldn’t likely see much in the way of more accuracy.
Thank you!
