I m trying to use the scd41 sensor with a esp32 thing plus c board. I use several other sensors with this board with no problems. However, every example ino in the sparkfun scd4x arduino library fails to execute, and instead constantly reboots .
The scd41 is the only sensor on the i2c bus, so no address conflicts.
Odd; what’s showing @ serial monitor? There’s a debug mode too if you know how to fanagle that kind of thing https://github.com/sparkfun/SparkFun_SC … ibrary.cpp
I don’t have one to test with, but I found Sensiron’s library in a comment on our product page https://github.com/Sensirion/arduino-i2c-scd4x - try that one out and see/report back?
Also ensure whatever is providing power (supply + cable) are pushing enough mA (probably not an issue, but worth verifying since it is power-cycling)
