I couldn’t find it in the datasheet so I would like your help. ![]()
I would like to know the IR and Red light irradiation angles(glancing angle) of this Breakout.
( 30°? 60°? )
( 30°? 60°? )
If it’s not in the datasheet, you’re probably going to need to contact the sensor manufacturer for that information. I doubt sparkfun is going to know.
We’re limited to the datasheet as well :-/ https://cdn.sparkfun.com/assets/8/1/c/9 … k4MDc1Nzg3
You might have luck contacting Maxim directly and seeing what they say ![]()
Thanks YellowDog, Thanks Russell
I recently checked that, in an enclosed space, the Breakout can recognize things from quite far away using only that light. So I wanted to know where I could see all that light, so I was curious about the angle.
