[SEN-18088] SparkFun 2D Barcode Scanner Breakout
Hi, I want to use this scanner module in our project. I need the FOV since I need to find an appropriate place to fixture it, but I couldn’t find it in the datasheet, only scanning angle and depth of field. Is this something I can calculate and how is this done?
It isn’t listed :-/
You could calculate it using Trigonometry identities (you know the vector distance and theta)
