Hi SparkFun Team,
I’m currently working on designing an enclosure for the SparkFun 2D Barcode Scanner Breakout (SKU: SEN-18088) and was wondering if a 3D model (STEP/STL file) of the scanner is available. I checked the GitHub repository but couldn’t find it there.
If the model is available, could you please share a link or provide the file? It would help us in designing and 3D Printing.
Looking forward to your response. Thanks in advance for your help!
Mostly - we make the eagle files available and you can export STL/STEP from them, here they are for the scanner (under ‘documentation’ on the product page) https://cdn.sparkfun.com/assets/3/4/4/8/8/2D_Barcode_Scanner_Breakout.zip
Thanks for the reply, but I already have found the flies you provided. I have created the board from those files, what I don’t have is the 3D files for the components on the board. If you don’t have the 3D model of the complete board, do you have the model of the camera module (DE2120) or any source where I can find it? I need to be as accurate as possible for the openings of the camera and other sensors.
there are a few more dimensions here https://cdn.sparkfun.com/assets/6/4/6/1/f/DY_SCAN_Specification-DE2120_1___2_.pdf
I could try measuring any needed specific measurements (I have one) tomorrow if that helps…but all I have is a micrometer
