Thanks for the quick response.
We envision up to 5 switches and maybe 2-3 knobs.
As an advanced version an onscreen menu system with to select commands would be awesome.
I looked up the MSP430 part number and there are a lot of choices.
Here is technical I have on how the serial interface works. Let me know what you think.
THANK YOU.
"The camera is compatible with most RS232 drivers/receivers but does not implement signaling levels compliant with the RS232 standard voltage levels.
The camera is capable of being controlled remotely through an asynchronous serial interface consisting of the signals named RX, TX, and GND using 3.3 volt signal levels.
The camera does not generate an outgoing message except in reply to an incoming message.
• The camera generates an outgoing reply to each incoming message.
• All messages, both incoming and outgoing, adhere to the packet protocol defined in Table B-2 and the subparagraphs that follow. The first byte i.e., the Process byte is transmitted first followed by the rest of the bytes in the order specified.
• All multi-byte arguments defined herein uses big-endian ordering (MSB first).
• The serial inter-byte timeout is factory set to 100ms
Example Process Code
Transmission is LSB first (for each byte) and most significant byte first on multi-byte messages. All bytes are preceded by a zero start bit and followed by a one stop bit.
The camera core is designed to talk to a PC serial port directly and may seem inverted if direct communication to a logic device is desired.
6E = 0 0111 0110 1 = Start bit, E with LSB first, 6 with LSB first, Stop bit
On an oscilloscope the observation is, Idle low but, zero high. Starting at idle, when the signal goes high, that is the first 0; then two 0’s high, three 1’s low, one 0 high, two 1’s low, one 0 high, one 1 low, (6E complete).
On all incoming and outgoing messages, the Byte-Count Bytes are used to specify the total number of data bytes in the packet.
• The Byte Count must be an even number from 0 to 0x1F4 (500 decimal).
The number of data bytes in the packet is not equal to the total number of bytes in the packet. For example, a No-Op serial command contains zero data bytes.)
CRC Bytes
• On all incoming and outgoing messages, two cyclical redundancy checks (CRCs) are calculated using CCITT-16 initialized to 0.
• CRC1 is calculated using only the first 6 bytes of the packet. • CRC2 is calculated using all previous bytes in the packet (i.e. bytes 0 through N).
