I have a problem where, after setting the time, the relay only lights its LED and makes a buzzing sound when the set time arrives. I think this is an issue in the code. Can you help me?
Objectives:
- I want the relay to turn ON when the set time arrives
- The relay should turn OFF after 3 seconds
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include <virtuabotixRTC.h>
// Relay pin
#define relay1 10
// RTC module pins
#define rtcVCC A5
#define rtcGND A4
#define rtcSCLK A3
#define rtcIO A2
#define rtcCE A1
// RTC object
virtuabotixRTC myRTC(rtcSCLK, rtcIO, rtcCE);
// Keypad
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// Mode
#define modeSETUP 1
#define modeNORMAL 2
int mode = 1; // Default mode
// EEPROM addressing
#define adr1ON 2
#define adr2ON 6
#define adr3ON 10
#define adr4ON 14
#define adr5ON 18
#define adr6ON 22
#define adr7ON 26
#define adr8ON 30
byte name0x1[] = { B11111, B10000, B10000, B10100, B10110, B11111, B00110, B00100 };
byte name0x2[] = { B11000, B00100, B00010, B00010, B11010, B00010, B00100, B11000 };
byte name0x3[] = { B00011, B00100, B01001, B01001, B01001, B01000, B00100, B00011 };
// UP
byte name1x4[] = { B00000, B00100, B01110, B11111, B01110, B01110, B01110, B00000 };
// DOWN
byte name1x5[] = { B00000, B01110, B01110, B01110, B11111, B01110, B00100, B00000 };
int eepromMin = 0;
int eepromHour = 0;
int eepromHourON = 0;
int eepromMinON = 0;
// LCD keypad shield pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int lcd_key = 0;
int adc_key_in = 0;
void setup() {
lcd.createChar(0, name0x1);
lcd.createChar(1, name0x2);
lcd.createChar(2, name0x3);
lcd.createChar(3, name1x4);
lcd.createChar(4, name1x5);
// Set all digital pins as output
for (int i = 0; i <= 13; i++) {
pinMode(i, OUTPUT);
// RTC module activation
pinMode(rtcVCC, OUTPUT);
pinMode(rtcGND, OUTPUT);
pinMode(rtcSCLK, OUTPUT);
pinMode(rtcIO, OUTPUT);
pinMode(rtcCE, OUTPUT);
digitalWrite(rtcVCC, HIGH);
digitalWrite(rtcGND, LOW);
delay(500);
// LCD initialization
lcd.begin(16, 2);
void loop() {
lcd.setCursor(4, 0);
// Display hours:minutes:seconds
displayTime();
// Set & display relay based on EEPROM data
lcd.setCursor(0, 1);
lcd.print("1");
relayAction(adr1ON, 1, relay1);
lcd.setCursor(2, 1);
lcd.print("2");
relayAction(adr2ON, 3, relay1);
lcd.setCursor(4, 1);
lcd.print("3");
relayAction(adr3ON, 5, relay1);
lcd.setCursor(6, 1);
lcd.print("4");
relayAction(adr4ON, 7, relay1);
lcd.setCursor(8, 1);
lcd.print("5");
relayAction(adr5ON, 9, relay1);
lcd.setCursor(10, 1);
lcd.print("6");
relayAction(adr6ON, 11, relay1);
lcd.setCursor(12, 1);
lcd.print("7");
relayAction(adr7ON, 13, relay1);
lcd.setCursor(14, 1);
lcd.print("8");
relayAction(adr8ON, 15, relay1);
// If the user presses the SELECT button, enter the settings menu
if (read_LCD_buttons() == btnSELECT) {
while (read_LCD_buttons() == btnSELECT);
lcd.clear();
lcd.setCursor(0, 0);
lcd.write(byte(3));
lcd.print(" TIME SETTING");
lcd.write(byte(4));
lcd.print(" CYCLE SETTING");
while (read_LCD_buttons() == btnNONE);
if (read_LCD_buttons() == btnUP) {
while (read_LCD_buttons() == btnUP);
setRTC(); // If the user presses the UP button, enter RTC settings menu
else if (read_LCD_buttons() == btnDOWN) {
while (read_LCD_buttons() == btnDOWN);
setPin(); // If the user presses the DOWN button, enter PIN settings menu
void relayAction(int adrON, int pos, int pin) {
myRTC.updateTime();
int MinToday = (myRTC.hours * 60) + myRTC.minutes;
int MinEprON = (EEPROM.read(adrON) * 60) + EEPROM.read(adrON + 1);
lcd.setCursor(pos, 1);
if (MinToday != MinEprON) {
lcd.print("-");
digitalWrite(pin, HIGH);
else if (MinToday = MinEprON) {
if (myRTC.seconds >= 3) {
lcd.print("-");
else {
lcd.print("*");
digitalWrite(pin, LOW);
// Setup function
void setRTC() {
lcd.clear();
lcd.print("TIME SETTING");
delay(1000);
lcd.clear();
lcd.print("CURRENT ");
setupShowValue2(myRTC.hours, myRTC.minutes, 0);
lcd.print("NEW ");
myRTC.updateTime();
setupShowValue(myRTC.hours, myRTC.minutes, 1);
setupChooseValueSetRTC(myRTC.hours, myRTC.minutes, 1);
lcd.setCursor(0,0);
lcd.print("SETTINGS SAVED ");
delay(1000);
lcd.clear();
void setPin() {
lcd.clear();
delay(3000);
lcd.clear();
lcd.setCursor(3, 0);
lcd.write(byte(0));
lcd.print("CYCLE 1 :");
eepromHour = EEPROM.read(adr1ON);
eepromMin = EEPROM.read(adr1ON + 1);
if (eepromHour >= 24) eepromHour = 0;
if (eepromMin >= 60) eepromMin = 0;
lcd.setCursor(13, 0);
lcd.write(byte(2));
lcd.setCursor(14, 0);
lcd.write(byte(1));
setupShowValue(eepromHour, eepromMin, 0);
setupChooseValue(eepromHour, eepromMin, adr1ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 2 :");
eepromHour = EEPROM.read(adr2ON);
eepromMin = EEPROM.read(adr2ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr2ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 3 :");
eepromHour = EEPROM.read(adr3ON);
eepromMin = EEPROM.read(adr3ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr3ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 4 :");
eepromHour = EEPROM.read(adr4ON);
eepromMin = EEPROM.read(adr4ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr4ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 5 :");
eepromHour = EEPROM.read(adr5ON);
eepromMin = EEPROM.read(adr5ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr5ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 6 :");
eepromHour = EEPROM.read(adr6ON);
eepromMin = EEPROM.read(adr6ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr6ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 7 :");
eepromHour = EEPROM.read(adr7ON);
eepromMin = EEPROM.read(adr7ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr7ON, 0);
lcd.clear();
lcd.write(byte(0));
lcd.print("CYCLE 8 :");
eepromHour = EEPROM.read(adr8ON);
eepromMin = EEPROM.read(adr8ON + 1);
lcd.write(byte(2));
lcd.write(byte(1));
setupChooseValue(eepromHour, eepromMin, adr8ON, 0);
lcd.clear();
void setupChooseValue(int HourNew, int MinNew, byte Address, byte Pos) {
while (read_LCD_buttons() != btnSELECT) {
if (read_LCD_buttons() == btnRIGHT) {
if (HourNew < 23) {
HourNew++;
else if (read_LCD_buttons() == btnLEFT) {
if (HourNew > 0) {
HourNew--;
else if (read_LCD_buttons() == btnUP) {
if (MinNew < 59) {
MinNew++;
if (MinNew > 0) {
MinNew--;
setupShowValue(HourNew, MinNew, Pos);
delay(150);
while (read_LCD_buttons() != btnNONE); // Wait until the button is released
EEPROM.write(Address, HourNew);
EEPROM.write(Address + 1, MinNew);
delay(150);
void setupChooseValueSetRTC(int HourNew, int MinNew, byte Pos) {
if (HourNew < 23) {
HourNew++;
if (HourNew > 0) {
HourNew--;
if (MinNew < 59) {
MinNew++;
if (MinNew > 0) {
MinNew--;
delay(150);
myRTC.setDS1302Time(00, MinNew, HourNew, 6, 10, 1, 2014);
delay(150);
void setupShowValue(int Hour, int Min, int Pos) {
//lcd.setCursor(11, Pos);
lcd.setCursor(11, 1);
print2digits(Hour);
lcd.print(":");
print2digits(Min);
void setupShowValue2(int Hour, int Min, int Pos) {
print2digits(Hour);
lcd.print(":");
print2digits(Min);
// LCD funtions
int read_LCD_buttons()
adc_key_in = analogRead(0); // Read the value from the sensor
if (adc_key_in > 1000) return btnNONE;
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 150) return btnUP;
if (adc_key_in < 300) return btnDOWN;
if (adc_key_in < 500) return btnLEFT;
if (adc_key_in < 850) return btnSELECT;
return btnNONE; // When all others fail, return this.
void eeprom_write_int(int p_address, int p_value) {
byte lowByte = ((p_value >> 0) & 0xFF);
byte highByte = ((p_value >> 8) & 0xFF);
EEPROM.write(p_address, lowByte);
EEPROM.write(p_address + 1, highByte);
unsigned int eeprom_read_int(int p_address) {
byte lowByte = EEPROM.read(p_address);
byte highByte = EEPROM.read(p_address + 1);
return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
void displayTime() {
myRTC.updateTime();
print2digits(myRTC.hours);
lcd.print(":");
print2digits(myRTC.minutes);
lcd.print(":");
print2digits(myRTC.seconds);
void print2digits(int number) {
if (number >= 0 && number < 10)
lcd.print('0');
lcd.print(number, DEC);
