set up winavr for bootloader logomatic
I have installed WinAVR and WinARM to my system. I followed the installation procedure as written down in the bootloader tutorial. I opened the main file in the programmers notepad and tried make all followed by this message. I included the path as set in the computer configurations. Does anyone know where to look?
“make.exe” all
-------- begin (mode: ROM_RUN) --------
arm-elf-gcc (GCC) 4.1.1 (WinARM)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Assembling (ARM-only): Startup.S
arm-elf-gcc -c -mcpu=arm7tdmi-s -mthumb-interwork -I. -x assembler-with-cpp -DROM_RUN -D__WinARM__ -Wa,-adhlns=Startup.lst,-gdwarf-2 Startup.S -o Startup.o
arm-elf-gcc: CreateProcess: No such file or directory
make.exe: *** [Startup.o] Error 1
Process Exit Code: 2
Time Taken: 00:00
C:\WinAVR\bin;C:\WinAVR\utils\bin;C:\WinARM\bin;C:\WinARM\utils\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared;C:\Program Files\QuickTime\QTSystem\
Problem solved, nothing was wrong. You have to start programmers notepad from pn.exe
You can find an explanation on this link:
http://winarm.scienceprog.com/winarm-to … inarm.html
I can make all with errors none now.
