I have read about 20 different .pdf’s installed a few different things like RSTerm, WinPython, etc. Am I just missing something here?
I have worked on this for a few days now and have finally been able to get SMS and GPRS stuff to work and incoming calls to the module seem to work just fine but no outgoing calls work. ATDAREACODEANDNUMBER and all I can still get is a “NO CARRIER”. For the life of me I can not figure out how someone is expected to actually be able to set on of these up to work for their service.
The service I use is Cingular. I have read more then I care to recall and still have not found anything that explains how to set this module up from the start. When I do things like AT+CREG? I get a 0,5 back which means I am roaming when I should not be. I have looked through settings like AT+COPS which needs the OPERATOR information from your service and when you do a AT+COPN it lists all of the operators but Cingular is not in there. So I look on the web and find the operator number for Cingular and it looks like the Country code is 310 and the Network Number is 180 so together that is 310180 and I tried to use that and that apparently is not right either.
Is there something I am just missing? Some .pdf that I have missed that explains the settings you must use to properly setup the GM862? Or did I just plain miss reading the right .pdf files?
I have also registered on the forums for roundsolutions two days ago and am still waiting for Administrator approval to gain access to the forums.
Someone help me and I would be happy to right up a tutorial for others who are having the same issues as I am.
Any help please?
