SHT25 I2C Temperature & Humidity sensor
I’d love to see a breakout board for a SHT25 on top of the one for SHT15 you already have. It has similar specs to the SHT15, but is in a smaller, more standard package, and is I2C instead of an incompatible 2-wire protocol.
I second that
The engineers are looking into the SHT25. No guarantees, but we may eventually get something on the store front. Thanks for the input though! I’ll make sure they are notified.
That’s good news, SHT25 seems to be the most precise sensor on the market, but there aren’t any breakout boards on sale.
Well, until they come out with a red PCB version, you can find a blue PCB version of a [SHT25 breakout at Embedded Adventures.](Embedded Adventures - Products - SHT25 temperature and humidity module)
Check out page 4, figure 6 on the TMP102:
http://www.ti.com/lit/ds/symlink/tmp102.pdf
The chip is mostly sub ±0.05C errors at room temperature if I read that right so SFE’s TMP102 BOB is pretty darn good and does I2C just fine:
https://www.sparkfun.com/products/9418
but the TMP102 only measures temperature. The SHT25 also measures humidity.
/mike
