A simple 1-wire humidity + temp sensor can abe also made with a Dallas Semi’s DS2438 + Honeywell’s HIH3610. The whole thing can be bus powered and several of them can be hooked up. IIRC sensormag had an article on building the 1-wire humidity module sometime back.
Too bad they didn’t put a temp sensor on the DS2450 (quad ADC).
Well, for the DS2450, you can add in the DS18S20 in the same MicroLAN/1-Wire line and select the device to read from all via software, quite elegant isn’t it
