If we look at this code:
#include <SparkFunSi4703.h>
#include <Wire.h>
int resetPin = 2;
int SDIO = A4;
int SCLK = A5;
int STC = 3;
Si4703_Breakout radio(resetPin, SDIO, SCLK, STC);
int channel;
int volume;
char rdsBuffer[10];
void setup()
Serial.begin(9600);
Serial.println("\n\nSi4703_Breakout Test Sketch");
Serial.println("===========================");
Serial.println("a b Favourite stations");
Serial.println("+ - Volume (max 15)");
Serial.println("u d Seek up / down");
Serial.println("r Listen for RDS Data (15 sec timeout)");
Serial.println("Send me a command letter.");
radio.powerOn();
radio.setVolume(0);
void loop()
if (Serial.available())
char ch = Serial.read();
if (ch == 'u')
channel = radio.seekUp();
displayInfo();
else if (ch == 'd')
channel = radio.seekDown();
displayInfo();
else if (ch == '+')
volume ++;
if (volume == 16) volume = 15;
radio.setVolume(volume);
displayInfo();
else if (ch == '-')
volume --;
if (volume < 0) volume = 0;
displayInfo();
else if (ch == 'a')
channel = 930; // Rock FM
radio.setChannel(channel);
displayInfo();
else if (ch == 'b')
channel = 974; // BBC R4
displayInfo();
else if (ch == 'r')
Serial.println("RDS listening");
radio.readRDS(rdsBuffer, 15000);
Serial.print("RDS heard:");
Serial.println(rdsBuffer);
void displayInfo()
Serial.print("Channel:"); Serial.print(channel);
Serial.print(" Volume:"); Serial.println(volume);
We see the line radio.readRDS(rdsBuffer, 15000);, however, this is blocking. The 15000 is how long (milliseconds) it will listen before timing out. Does anyone one know if there is a way to make it non blocking, so it can listen in the background while I do other things (like change volume etc)?
