Yes I am looking for a simpler transceiver. The reason it needs to be 2.4ghz is it will be simpler for FCC approval. I am having trouble finding products that will send a simple address, with no need to transmit much data.
Would the TLP-434 work? It sounds like what you might need. It is under the General category on wireless on SparkFun’s main website, and it comes in 4 different types
Did you ever get this to work, cause im trying to achive the same goal. I just need to transmit an on signal to a reciever to light up an led, thats it. If so could you send me the schematic and any code you used if any. Thanks its greatly appreciated!!!
nathad:
Thank you stevech!
I’ve bought the HT-12D and HT-12E decoder/encoder as suggested below, and have realized how naive I am.
I have no development board to use with the RF-24G and am unable to configure the transceiver to send data or receive data for that matter.
Is there a way to send data with out any configuration of the nRF2401?
I’ve got a PCB design and software for a very simple Tx and Rx pair using SFE nRF24L01 modules and PIC18F4520 chips. The boards have a pushbutton and LED.
