Give the minimum drill and pad sizes, how do I mount a SIP device that has 0.05" pin spacing? This device is not an SMD device, but 0.05" pin space seems to make it impossible to build on a board with 8 mil clearences? Any advice? (The device is the HMC1021Z magnetometer)
.05 is 50 mils try this out http://www.unitsconverter.net/
Have you looked at the data sheet for the HMC1021Z and the specs for Spark Fun’s PCBs?
What is the problem?
What was wrong with the response you got before?
I have absolutely no idea how the second post appeared. I only posted it once! There is no problem. ![]()
