SM-24 geophone with HORIZONTAL component
I need an SM-24 geophone with a horizontal component, but I couldn’t find an option to select this orientation on the website. Is the horizontal component available upon request?
Thank you!
Since the vertical SM-24 seems to be backordered on Sparkfun, consider buying similar models in the horizontal configuration from other suppliers, for example RTC 10HZ 395OHM HORIZONTAL GEOPHONE - R. T. Clark
