Hi guys
I tried to save the channel and address data into the eeprom but it doesn’t work.
I send the following commands:
putchar(20);
putchar(20);
putchar(20);
putchar(20);
putchar(20);
delay_ms(100);
putchar(49);
putchar(15);
putchar(50);
putchar(30);
putchar(52);
putchar(0);
delay_ms(20);
putchar(120);
But just the smirf change the new setting but when I turned off and power again the new setting are the default 2400 0 0
Can someone help me?
sparky
February 18, 2005, 4:43pm
2
Looks like a good start.
Just so others know:
putchar(20);
putchar(20);
putchar(20);
putchar(20);
putchar(20); //ctl+t 5 times for quiet menu
delay_ms(100);
putchar(49); //'1'
putchar(15); //channel 15
putchar(50); //'2'
putchar(30); //address 30
putchar(52); //'4' record to eeprom
putchar(0); //??
delay_ms(20); //wait for record to eeprom
putchar(120); //'x'
Looks fine except for the putchar(0) - not sure what you are doing there.
Is the SMiRF on the correct channel and address before you power the unit down?
-Nathan
hi Nathan
I read from the smirfv 2.0 datashet to put the ‘4’ and then 0 to save the data in the eeprom or am I wrong??
when I run the code, the smirf change the values to the new ones but when I turn it off and then turn it on the value are cleared and reseted.
when I tried this code:
putchar(20);
putchar(20);
putchar(20);
putchar(20);
putchar(20);
delay_ms(100);
putchar(49);
putchar(20);
putchar(50);
putchar(30);
//putchar(52);
delay_ms(20);
putchar(120); ----> breakpoint
With breakpoint in the last line, I press start again the microcontroller and the smirfv2 goes out from the quick configuratio menu.
When I tried this code:
putchar(20);
putchar(20);
putchar(20);
putchar(20);
putchar(20);
delay_ms(100);
putchar(49);
putchar(20);
putchar(50);
putchar(30);
putchar(52);
delay_ms(20);
putchar(120); —> breakpoint
The smirfv2 still be in the quick configuration menu and never goes out.
What is hapenning???
