This may seem blatantly obvious, but I wish Sparkfun provided something dirt simple, as a Artemis option, to use a standard iron and solder to a custom PCB.
Wouldn’t need to be PTH necessarily, but perhaps surface mount, yet easy to use?
I would be happy to pay a couple of dollars more, if I was sure I could fabricate successfully.
I understand the apprehension of soldering SMD parts using solder paste but I must say that once you try and develop that skill you will probably enjoy it a lot. For me it is the surface tension. That little aspect of physics makes it possible for me to solder things much smaller than I could ever do “by hand” with an iron.
Solder paste - I like to get the kind that comes in a syringe b/c it helps application (at least until you graduate to using stencils)
An x-acto knife to clean up applied solder.
With just those tools you can solder all but the most difficult SMD parts. If you want even better results you might try:
Flux in a syringe-tipped bottle
A griddle with sand to evenly heat the bottom of your PCB (I use this for large/difficult boards when I only have a hot air gun - it helps pre-heat the entire board)
