We are using the GNSS to collect data for a tracking device that is going to be put on a reptile in the wild. While running tests with the GNSS, the antenna ( can be seen here: https://www.sparkfun.com/products/177 ) is working sometimes and sometimes it fails to even connect which stops the GNSS from collecting data. We have used the other antenna ( can be seen here: https://www.sparkfun.com/products/14986 ) and it works fine, allowing the GNSS to collect data indicated by the LED that beeps blue light every couple seconds on the module. Any help would be great, thanks!
Related topics
| Topic | Replies | Views | Activity | |
| SparkFun GPS Breakout - ZOE-M8Q (Qwiic) not working proerly | 1 | 244 | December 7, 2022 | |
| my sparkfun rtk gps2 do not work... plz help me... | 1 | 1707 | July 1, 2019 | |
| GPS Breakout - XA1110 (Qwiic) examples fail to compile | 12 | 3598 | May 12, 2023 | |
| Issue with connecting ZED-F9P GPS modules | 3 | 802 | October 13, 2023 | |
| SparkFun GPS-RTK-SMA Breakout - ZED-F9P GNSS Antenna specs | 1 | 148 | May 16, 2023 |
