Sparkfun Artemis Open log - on board IMU sensors non responsive
Hi Nick,
The OLA needs a little persuasion to log that fast:
Use Menu 3 to disable any IMU readings you don’t need. I guess you don’t need to log temperature? Disabling that will help.
Use Menu 2 to disable the time stamp logging. That will help too.
Use Menu 1 to disable “Log to Terminal”. I guess you don’t need to see the data whizz up the screen?
Exit the menus. Let the OLA log the IMU data for a few seconds. The blue STAT LED should be lit up almost continuously.
Open Menu 1 again. Choose Option 4. The maximum value should now be in excess of 200 Hz.
The ultimate speed depends on the SD card. My OLA is currently running at 220Hz.
