SparkFun Differential I2C Breakout - PCA9615: How to connect multiple devices in Star Configuration
About this https://www.sparkfun.com/products/14589 … 691b605f74 video: Lets supose I want to connect another “SparkFun Differential I2C Breakout” to the unused Qwiic connector in the first “SparkFun Differential I2C Breakout”. Is that possible? How about the terminator resistors?
I read somewhere “Termination resistors only on the first and last peripheral on I2C Bus”. How can i do this? since in this case will be a termination resistor in different “nodes”.
My goal is to add like 5 sensors to the some I2C bus point, using 5 RS485 20meters cable and 6 “SparkFun Differential I2C Breakout” (one for each sensor to convert the differencial signal to signal end) and another one to the point where all the signals will converg. Is that possible?
The way the boards are setup, these are point to point only where you have a local board and a remote board. I don’t believe you can connect any more than two together.
