Request any advice/suggestion on what I am doing wrong. I am trying to run the ‘hello world’ example on my Sparkfun Edge board as described in Chapter 6 of the TnyML book by Pete Warden & Daniel Situnayake. Here is my setup:
laptop: Dell Latitude E7450 running on Ubuntu 18.04 LTS
Attached Sparkfun board with serial basic breakout to a USB port on my laptop
I then ran everything as described in the book as follows:
export DEVICENAME=/dev/ttyUSB0
export BAUD_RATE=921600
Then held down button 14 on the Sparkfun board, reset by pressing RST, and then ran the python program as below.
It prints the ‘Sending Hello’ message, runs some blocks of the code for a bit, and after some time it produces the error message as shown. And the same result with many tries.
Appreciate any input.
nwoke@Tobiee:~/Documents/git_cloned/Github/tflite-micro-sparkfun$ export DEVICENAME=/dev/ttyUSB0
nwoke@Tobiee:~/Documents/git_cloned/Github/tflite-micro-sparkfun$ export BAUD_RATE=115200
nwoke@Tobiee:~/Documents/git_cloned/Github/tflite-micro-sparkfun$ python3 tensorflow/lite/micro/tools/make/downloads/AmbiqSuite-Rel2.2.0/tools/apollo3_scripts/uart_wired_update.py -b ${BAUD_RATE} ${DEVICENAME} -r 1 -f main_nonsecure_wire.bin -i 6
Connecting with Corvette over serial port /dev/ttyUSB0…
Sending Hello.
No response for command 0x00000000
File “tensorflow/lite/micro/tools/make/downloads/AmbiqSuite-Rel2.2.0/tools/apollo3_scripts/uart_wired_update.py”, line 338, in
main()
File “tensorflow/lite/micro/tools/make/downloads/AmbiqSuite-Rel2.2.0/tools/apollo3_scripts/uart_wired_update.py”, line 40, in main
connect_device(ser)
File “tensorflow/lite/micro/tools/make/downloads/AmbiqSuite-Rel2.2.0/tools/apollo3_scripts/uart_wired_update.py”, line 60, in connect_device
response = send_command(hello, 88, ser)
File “tensorflow/lite/micro/tools/make/downloads/AmbiqSuite-Rel2.2.0/tools/apollo3_scripts/uart_wired_update.py”, line 237, in send_command
raise NoResponseError
main.NoResponseError
nwoke@Tobiee:~/Documents/git_cloned/Github/tflite-micro-sparkfun$ export BAUD_RATE=921600
Sending Hello.
Received response for Hello
Received Status
length = 0x58
version = 0x3
Max Storage = 0x4ffa0
Status = 0x2
State = 0x7
AMInfo =
0x1
0xff2da3ff
0x55fff
0x1
0x49f40003
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
Sending OTA Descriptor = 0xfe000
Sending Update Command.
number of updates needed = 1
Sending block of size 0x393d8 from 0x0 to 0x393d8
Sending Data Packet of length 8180
Sending Data Packet of length 5416
Received NACK
msgType = 0x8
error = 0x7
seqNo = 0x0
!!!Wired Upgrade Unsuccessful!!!..Terminating the script
Cheers
Nwoke
