SparkFun EL Sequencer - COM-11323
Complete noob question.
I have recently purchased a few of these boards along with item “FTDI Cable 5V VCC-3.3V I/O - DEV-09717”.
I am trying to use the Arduino IDE to upload the example script to the board but it keeps failing to upload. I have tried both (LilyPad Arduino, LilyPad Arduino USB) board types. with the default Programmer (AVRISP mkll). The IDE is seeing the Serial Port and I have installed the latest FTDI drivers.
Any help would be greatly appreciated.
PS. I am Running Win10.
In the Arduino IDE, go to preferences and turn on verbose output on upload. Copy and paste the error in CODE tags, please.
This is the entire error log
Arduino: 1.6.6 (Windows 10), Board: "LilyPad Arduino, ATmega328"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\devin\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\devin\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\devin\Documents\Arduino\libraries" -fqbn=arduino:avr:lilypad:cpu=atmega328 -ide-version=10606 -build-path "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\devin\Documents\Arduino\sketch_nov05a\sketch_nov05a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\devin\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\devin\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\devin\Documents\Arduino\libraries" -fqbn=arduino:avr:lilypad:cpu=atmega328 -ide-version=10606 -build-path "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\devin\Documents\Arduino\sketch_nov05a\sketch_nov05a.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -M -MG -MP -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10606 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR   "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\cores\arduino" "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\variants\standard" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\sketch\sketch_nov05a.ino.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10606 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR   "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\cores\arduino" "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\variants\standard" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\sketch\sketch_nov05a.ino.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino2/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\preproc\ctags_target.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10606 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR   "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\cores\arduino" "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\variants\standard" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\sketch\sketch_nov05a.ino.cpp" -o "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\sketch\sketch_nov05a.ino.cpp.o"
C:\Users\devin\Documents\Arduino\sketch_nov05a\sketch_nov05a.ino: In function 'void loopUp()':
C:\Users\devin\Documents\Arduino\sketch_nov05a\sketch_nov05a.ino:35:11: warning: unused variable 'status' [-Wunused-variable]
     int x,status;
C:\Users\devin\Documents\Arduino\sketch_nov05a\sketch_nov05a.ino: In function 'void loopDown()':
C:\Users\devin\Documents\Arduino\sketch_nov05a\sketch_nov05a.ino:46:9: warning: unused variable 'status' [-Wunused-variable]
   int x,status;
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10606 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR   "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\cores\arduino" "-IC:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\variants\standard" "C:\Users\devin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.9\cores\arduino\wiring_pulse.S" -o "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_pulse.S.o"
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\WInterrupts.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\hooks.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_analog.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_digital.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_shift.c.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\CDC.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\Print.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\Stream.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\Tone.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\USBCore.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\WMath.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\WString.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\abi.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\main.cpp.o
Using previously compiled file: C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\new.cpp.o
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_pulse.S.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\WInterrupts.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\hooks.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_analog.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_digital.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_pulse.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\wiring_shift.c.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\CDC.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial0.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial1.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial2.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\HardwareSerial3.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\IPAddress.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\PluggableUSB.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\Print.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\Stream.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\Tone.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\USBCore.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\WMath.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\WString.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\abi.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\main.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\core.a" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\core\new.cpp.o"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -Wall -Wextra -Os -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/sketch_nov05a.ino.elf" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp\sketch\sketch_nov05a.ino.cpp.o" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/core\core.a" "-LC:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/sketch_nov05a.ino.elf" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/sketch_nov05a.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/sketch_nov05a.ino.elf" "C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/sketch_nov05a.ino.hex"
Sketch uses 1,332 bytes (4%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\devin\AppData\Local\Temp\build6b2bb8f903c95415bcbc08a58caaf68a.tmp/sketch_nov05a.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x76
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x76
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Are you trying with the MKII or with the FTDI? The MKII will delete the bootloader so you will need to burn it before using FTDI.
Also make sure you have selected the right programmer under tools.
What would be the correct bootloader to use? And I am using the ftdi cable
Arduino Uno
I have tried to burn the bootloader and still getting the same “programmer is not responding” error what programmer should i be using?
Arduino: 1.6.6 (Windows 10), Board: “LilyPad Arduino, ATmega328”
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM3
Using Programmer : stk500v1
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
I have figured it out.
I had used an Arduino-Duemilanove to ‘jump’ the FTDI on to the EL board and program it that way.
AS out lined here “http://www.instructables.com/id/Arduino … TDI-Progr/”
Thanks Ross for all the Help.
-Devin
Interesting. I have the same Sequencer and I couldn’t reproduce your error. Tried a number of different boards with a '328 using my FTDI cable… The only difference is I’m on Win7 or you’re on 10.
Thanks for posting up the solution.
