Hi guys does anyone know how to wire up the SparkFun LoRaSerial Kit - 915MHz (Enclosed) kit to an Ardusimple simpleRTK2B Lite board ? I have two boards one setup as a Rtk base station and the other on the tractor as a rover . Thanks
Looking at the [Ardusimple Hookup Guide would be a good start. You should be able to connect the serial pins from the Ardusimple to the LoRa module’s serial port.
Also take a look at the LoRa [hardware overview for additional guidance.
Past that point you’re getting into some deeper engineering territory outside of SparkFun’s targeted application.](Hardware Overview - SparkFun LoRaSerial Product Manual)](simpleRTK2B hookup guide - ArduSimple)
