SparkFun micro:climate kit for micro:bit - v3.0
I’d like to purchase the SparkFun micro:climate kit for micro:bit - v3.0, however, I noticed that currently there is no micro:bit in stock.
So I believe this should not be a problem, because I can use I2C to connect the micro:climate to SparkFun Photon RedBoard, or any standard Arduino with an additional Wireless Board to collect data from the micro:climate, and then send it to other devices over 2.4 Ghz or LTE.
Can anyone please confirm this? Thanks.
You would still need a micro:bit processor if wanting to perform ADC/DAC onboard; seeed has some https://www.seeedstudio.com/MICRO-BIT-S … -5294.html
But the rest is accurate…check the schematic https://cdn.sparkfun.com/assets/c/1/a/7 … ematic.pdf to ensure that the circuits you’d like to use are available
