Using SparkFun weather:bit with Arduino board
Does anybody know if SparkFun weather:bit is compatible with Arduino board, instead of using micro:bit Board (Part SKU: DEV-14214)?
Any instruction on this?
Thanks.
Rodrigo
Hello Rodrigo,
They are not directly compatible. The large 52-pin connector is connected to all the sensors you’ll want to talk to. If you were to make a way (or wire) to connect those pinouts to an Arduino, then it could be possible. Unfortunately, we don’t have anything that can accomplish this directly.
