What are the component heights of the Sparkfun Openlog Artemis board? I can’t seem to find this anywhere on the internet.
The closest thing we’ll have available will be the .brd files here https://cdn.sparkfun.com/assets/f/d/5/b … latest.zip which can be opened/navigated through using AutoDesk EAGLE - hope this helps!
The tallest component on the board is 5.5mm tall and the board itself is about 1.6mm thick so you’re looking at less than 8mm for a total height. ![]()
