Hello Team,
I am working on SparkFun Pro nRF52840 Mini - Bluetooth … ment Board . I have followed the Hookup Guide and VS Code Guide step by step. I was able to run the Blikny app as given in the VS Code guide. But when I am trying to compile the BLE_APP_BLINKY app with all the required changes I am running into compilation errors.
Please find the screenshots and target folder for sparkfun nrf52840 attached here for your reference.
I am using Windows 10 system and nRF SDK version 16.0.0
https://learn.sparkfun.com/tutorials/sp … 1583356289
https://learn.sparkfun.com/tutorials/nr … e-nrf5-sdk
can you try to copy /paste the tekst or store a larger version on another website and provide a link. This is picture is not readable and can not help.
Hi Paul,
As requested, please find the image here: https://drive.google.com/file/d/1v_zqI … sp=sharing
Thank you
Hardik
Hi Paul,
I found the solution and it is working now. The problem was with path length for the source and header files. Shortening the path solved the problem.
Thank you!
