I have been having a hard time finding a solution to my problem. I copied code from Sparkfun’s hookup guide and I cannot get it to compile. I will admit I am not the best coding but I didn’t think Sparkfun would post code that would cause a problem. Error message I am getting is;
C:\Users\Red\AppData\Local\Temp\arduino_build_600700\sketch\Example1_config_BPM_Mode1.ino.cpp.o: In function `loop’:
C:\Users\Red\Documents\Arduino\Example1_config_BPM_Mode1/Example1_config_BPM_Mode1.ino:98: undefined reference to `Serial’
C:\Users\Red\AppData\Local\Temp\arduino_build_600700\sketch\Example1_config_BPM_Mode1.ino.cpp.o: In function `setup’:
C:\Users\Red\Documents\Arduino\Example1_config_BPM_Mode1/Example1_config_BPM_Mode1.ino:80: undefined reference to `Serial’
collect2.exe: error: ld returned 1 exit status
Using library SparkFun_Bio_Sensor_Hub_Library at version 1.0.5 in folder: C:\Users\Red\Documents\Arduino\libraries\SparkFun_Bio_Sensor_Hub_Library
Using library Wire at version 1.0 in folder: C:\Users\Red\Documents\ArduinoData\packages\SparkFun\hardware\samd\1.7.5\libraries\Wire
exit status 1
Error compiling for board SparkFun RedBoard Turbo.
Is there away to debug the code? I tried pasting code into VS Code and use debug but not luck.
I used Example 1 code, get errors with the other examples also.
I don’t know where else to look to resolve my problem. I’m sure I’m over looking something simple.
Thanks, Doug
