Hi Team,
We are planning to implement keystone correction to our short through projector using VL53L8CX.
From the ST team , we got assistance as "the easy way to do this is buy the sensor and a small MCU from SparkFun.
They have the code. And you can add to it."
Which MCU you suggest for this??
Do you have driver level support code for this ?? Can you provide the Link for the same.
For Initial testing purpose , can we test the keystone correction and autofocus by purchasing, Sparkfun Qwiic Mini TOF Imager-VL53L5CX with suggested MCU??
Thanks and Regards,
Deep_Bang
Here’s our code library for that sensor https://github.com/sparkfun/SparkFun_VL … no_Library (note src folder has the source code files)
Our hookup guide https://learn.sparkfun.com/tutorials/qw … are-hookup has 2 suggested MCUs, either of those in the blue box would be excellent choices
Also grab a qwiic cable and then pick back up @ that link/the guide
Hi Russell,
Thank you for the Info.
Do you have a Sparkfun board with VL53L8CX ??? and Supported code library for the same?
Regards,
Deep_Bang
Hi Russell,
Regards,
Deep_Bang
Not currently, just the L5
Hi Russell,
In this above link , angle calculation for keystone correction files are missing. Example folder does not have keystone correction related example. Where can I find it???
I don’t think sparkfun has an example for that. You’re going to need to take the example code they do have and modify it to suit your needs.
